Sump plug size?
mak
Sump plug size?
Postby mak » 01 Dec 2007 13:38
Being a slight gadget freak I was thinking of fitting one of these:
http://www.drainplug.co.uk/Products/Sta ... eries.html
Does anyone know the size of a TR7 sump plug, the workshop manual says 3/8" dryseal, but i'm sure that what was used on the spitfire and the TR7 one is metric, Can anyone shed any light on this please?
thanks
ACW30445
Postby ACW30445 » 01 Dec 2007 23:27
I believe it is dryseal...3/8"-18 unless my memory fails me if it has the original.
http://www.sae.org/technical/standards/J476_196106
So it wouldn't be metric if that's the case. Many of the fittings on the car are 'American'....with some metric, but most of the engine fittings are UNF (Unified Fine) or UNC (Unified Coarse) I believe.
Mine doesn't seal very dry any more....I need a little thread sealant to stop it dripping oil.
Dryseal is just a slight variation of NPT (National Pipe Taper), that is 'supposed' to not need any thread sealant. So to the best of my knowledge you would need a 3/8"-18 NPT fitting.
Of if you want a longer version of from 'Whitworth to Wedges' (catchy title isn't it?)
http://en.wikipedia.org/wiki/Screw_thre ... ardization
"Problems with lack of interchangeability among American, Canadian, and British parts during World War II led to an effort to unify the inch-based standards among these closely allied nations, and the Unified Thread Standard was adopted by the Screw Thread Standardization Committees of Canada, the United Kingdom, and the United States on November 18, 1949 in Washington, D.C., with the hope that they would be adopted universally. (The original UTS standard may be found in ASA (now ANSI) publication, Vol. 1, 1949.) UTS consists of Unified Coarse (UNC), Unified Fine (UNF), Unified Extra Fine (UNEF) and Unified Special (UNS). The standard was not widely taken up in the UK, where many companies continued to use the UK's own British Association (BA) standard."
But British Leyland finally did take it up by the 70s to a great extent and that's why there are so many non British Association and non Metric fittings on a wedge. It always puzzled me why that was.
mak
Postby mak » 02 Dec 2007 19:27
I've always wondered why there was such a mix of fittings on TR7's, thought it was just people using up old part stocks. Thanks for the answer to my question - I will report back on if the fancy drain plugs actually work or not!
Postby FI Spyder » 03 Dec 2007 05:45
The engine and I beleive transmission is SAE. Body is Metric. The confusion comes where they come together. Are the bolts metric or SAE? Of course you have the problem of PO's replacing nuts and bolts with what ever they have handy so you can't be sure.
mak
Postby mak » 03 Dec 2007 20:19
If anyone else is weak like me and tempted by gadgetry. For a TR7 it is part number DP1044.
Just seen a handy tip for making changing oil filters less messy by putting them in a bag before unscrewing them, will have to see if it works too...
