OK, I need some TR7 Electrics 101.
My 81 has an alternator that doesn't use a big plug on the back. Just a small one, and two threaded lugs - one heavy wire, one thin wire.
One the positive battery cable there's a black block with 4 terminals on it about 16" from the terminal end. There are 2 heavy red wires, one thin red wire, and on thin red wire with a loose fitting black sleeve.
If I pull one of the big or one of the thin red wires, it stops running. If I pull the other thick wire some electrics won't work, but it keeps running. If I pull the thin red one, I can't tell what happens, but it keeps running.
If I pull the positive cable, the engine revs a little higher, life a huge load has been lifted.
IT will run all day - just don't shut it off, because the battery isn't getting charged. I put a 10amp battery charger on it for a few minutes, it will crank over.
I've taken the alternator to Advance and Auto Zone, they both show a battery with a bug plug on the back, and can't test it.
Some further searching on the information super highway shows that this alternator was used on early-to-mid Jaguars. So, I'm guessing by the time my 81 rolled off, the bins with the correct electrics were empty, and they grabbed the next closest thing.
Will someone please tell me how my battery is supposed to be getting charged while it's running, and how c I test it. Pull both battery terminals while it's running and test the voltage across the cable ends?
I'm so ready to start getting it ready for daily driving, but need to sort out the charging system.
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Tim
