Postby jclay (RIP 2018) » 29 Oct 2007 23:50
OK, the clicking is coming from the blue relay, but nothing is happening at the starter.
First check that the red/orange wire has a good connection to the small lug. They are bad about corroding as water, durt and mud get thrown up on them.
The small wire white/orange wire on the small blade at the starter goes to the starter relay. There should be a Brown wire (goes to the back of the alternator) and the big red wire from the battery on the main lug of the starter.
If checking the red/orange didn't help, then use a test wire (two wires with a 12 volt bulb in the middle) to check that you are getting power at the red wire at the started. Ground one end of the test wire and touch the other to the red wire at the lug. If the bulb lights up you have power to the starter.
Pull the white/orange wire and connect the tag end of the test light to the wire. Turn the ignition switch to start. The relay should click and the test light should come on.
If the light comes on both times, the starter is probably bad. One last check Use a jumper wire from the big lug and touch it to the small blade lug. If the starter turns, then there is a bad connection somewhere.
