I'd also choose the Weber DCOE/Dellorto DHLA/Solex option.
For the reason mentioned above but they also flow better and ...
... they look and sound much better [:D]
On the other hand, a pair of (proper set up) SU HS6 carb's should give you proper results, even if the engine is tuned a bit.
<center>
