1976 Air Pump
striker308
1976 Air Pump
Postby striker308 » 21 Oct 2007 01:03
My air pump doesn't turn and doesn't have a belt on it. Is this pump something that I can rebuild/replace?
Karl
1976 TR7
1982 VW Scirocco
Postby jclay (RIP 2018) » 21 Oct 2007 01:48
Check your local emissions regulations. You might not need it any more. In Texas after the car is 25 years old, they don't check emissions. If you do get it working, you will probably start having backfiring through exhaust.
striker308
Postby striker308 » 21 Oct 2007 01:54
So, basically if I don't need it............just let it alone!!
Karl
1976 TR7
1982 VW Scirocco
Rblackadar
Postby Rblackadar » 22 Oct 2007 00:04
I rebuilt mine for $3.00...... really easy. I'm keeping mine on for originality sake. Mine was seized when I got it. What happens is the tiny little bakelite pieces (cheap plastic) breaks up and jams the flaps........Usually people don't want to take car of their vehicle so they just remove the belt and leave it alone.....then the thing sits and the bearing gets no use...so that siezes. I took mine apart, sprayed some penetrant into the bearing....loosened up in no time. It's sealed so all it needed was some working and is fine now. I also scratchbuilt the tiny bakelite spacer pieces but out of nylon this time.........works just fine now. It will probably last longer that I used nylon instead of the garbage they used for a friction part. Overall, the job was very easy.
Users browsing this forum: No registered users and 253 guests
