TR7 FI Coil Wires
Posted: 11 Oct 2007 01:11
The wires to my '81 coil have been "repaired" by the PO. All crimps. I preferr solder and heat-shrink.
I'm colorblind, so I asked the 5-year old to tell Daddy what color the wires are. There's a "greenish-blue" and a red. I'm guessing one should go to the distributor, and the other goes to the starter for current?
If I buy an aftermarket coil, if I remember correctly, there are 2 primary terminals. If looks like there's a third wire that didn't make the cut in the repair, but all I find is frayed wires. Any thoughts?
Not sure if these wire colors changed for the FI models.
Also, below the coil, under the master cylinder, there's a white plastic unit. Looks like you could thread a speedo cable on one side, then out the other. Like a cruise control module. An thoughts as to what it is?
I'll take pictures, if you like.
-Tim
-Tim
