It may be an interesting story this one but it's driving me crackers!
A misfire began some time ago that led me to call the good ol' RAC having established that nothing obvious (plugs, leads, condensor, coil etc. etc. etc.) would cure the problem. As the engine got hotter the problem got worse until it virtually stalled. If I didn't keep revving the engine it would have cut out altogether.
The conclusion of the RAC man was the head gasket. This was not my opinion and his conclusion rather shocked me as it was the last thing I would have thought of. I think the TR7 still suffers from the reputation it gained very early on.
The head was removed and taken to a local engine specialist who employ a chap who spent about 40 years on Triumph engines. New TriumphTune valves and guides were fitted and the tappet clearances set.
After reassembly there was a 'ticking' when the car was moving but at rest it was probably quieter than it has ever been. Going up inclines it was obviously down on power as I could feel it surging or misfiring (but not audibly). The timing and points were spot on.
I've been taking advice and playing around a bit today with a view to changing the timing chain but apparently a loose chain would not have caused the lack of power unless it had slipped - it hadn't. Then I risked taking it up the road again and it was misfiring badly. By the time I'd completely the few hundred yards trip the engine was misfiring exactly as it was when the RAC man diagnozed the cylinder head gasket.
I've just renewed the condenser again to prove it isn't that. Anyone got any ideas? Need any more information?
