Which electrical furl
Posted: 21 Sep 2018 10:19
I am thinking on fitting a new electric fuel pump i have found a supplier here in the uk
ie what about the Low pressure SU replacement carburettor Fuelflow 12v electronic fuel pump 15LM12 , The Fuelflow ECCO™ 15LM12 Diaphragm Pump is loosely styled on the original SU type electric fuel pump. It is a universal replacement fuel pump and has been specifically designed to suit as wide a scope of applications as possible.
The 15LM12 Diaphragm Pump would generally be used as a replacement fuel pump on carburetted vehicles that have 4 – 6 cylinder engines and a fuel requirement of up to 1.5 Litres per minute. Specifications Typically, these vehicles could be described as large cars with larger than average engines and a higher than normal fuel requirement.12 volts
Positive or Negative Earth
1.5 litres per minute flow
3 – 4 psi
Self Regulating
Solid State Electronics
3 – 4 psi
Self Regulating
