Page 1 of 4
AccuSpark Electronic Ignition
Posted: 21 Dec 2011 12:07
by Pete
Seasonal Greetings !
I'm considering electronic ignition as a crimbo present for my car (it's a surprise, the car doesn't know yet !).
On ebay, there's this Accuspark kit, but having trawled t'internet I can't find any reviews.
Anyone have any experience of these ?
Also there's the SimonBBC offering, anyone fitted one ?
Cheers and have a TRiffic Christmas
Pete
Posted: 21 Dec 2011 17:11
by dycecooper
I bought the Accuspark but it did not fit my oddball distributer (I still have it somewhere) I then bought a new distributor and coil from Simon. Brilliant!!!!
Posted: 22 Dec 2011 02:39
by Neil_W
http://www.aldonauto.co.uk/shop/product ... rtRecord=1
Aldonauto now do a Electronic Unit for TR7 - more expensive than Accspark.
Think others on this forum has used Aldon.
Like you I am looking to change my points system although so far they have been 100 % reliable.
When I phoned up Accspark they said they were developing the Unit for the TR7 as it was not previously listed on their Application List so now must be out.
If I remember Aldon has to be wired to the ignition Switch & Accspark goes to the 2 connections at the coil - so take your choice I suppose.
£40 delivered sounds cheap so think I will give it a try in the spring when I get the car out again.
Just does my back in & skins my fingers changing the points !
Oh yes this Company you would have to give a phone to find out info
http://www.ignitioncarparts.co.uk/PartL ... 8&s_ec=CG2
Posted: 22 Dec 2011 10:18
by willywonka
Recently fitted an Accuspark new distributor, coils and leads to an Escort RS2000.
Cost £95.00 delivered.
It made a huge improvement.
All the Gear, no idea
Posted: 27 Dec 2011 12:42
by TheBozz
You mean like this one Lol
I had exactly the same idea for a Xmas present for my Tr7 and bought the Accu Spark Stealth Kit 31. The trouble is I've bottled it a little as the car is running perfectly (I really shouldn't have said that!) So I will read the distructions and practice installing it on an out of the car distributor to see how easy or Not it is. I will report back.
TheBozz
1980 TR7 2.0 DHC
Posted: 27 Dec 2011 19:59
I fitted an Aldon Ignitor (Pertronix) a couple of years ago and have not looked at the points (or lack of) since. Cheapest from Retro Rockets in the States ( http://www.vintageperformance.com/retrorockets/) although they keep a stock at a warehouse in the UK, and they have very good support response to queries. Quite easy to fit although it does need a feed from the ignition switch (bypassing the ballast resistor). I drilled a second hole in the dizzy baseplate as I was a little wary and wanted the backup of being able to fit the points back if necessary, but it never has been - yet. I fitted it all from the top without removing the dizzy.
Saab 9000 Stg 1
Saab 9000 2.3 FPT Auto
Saab 2.3 LPT Auto
Posted: 28 Dec 2011 06:36
by Neil_W
Hi THE BOZZ,
Could you scan the fitting instructions complete 1 to 11 as Accuspark, as below, they say or the supp;lier it is simple to fit but hey can see from some of the Instruction sheet to remove the distributor - eh not quite 'just 2 wires ' !
Like you my TR7 is running fine but taking out the Distributor is another kettle of fish to upset the applecart.
http://www.ebay.co.uk/itm/310366247354? ... 1423.l2649
AccuSpark electronic ignition conversion for Delco distributor
Suitable all Triumph TR7 Models , Needs no other parts
The AccuSparkâ„¢ electronic ignition module completely replaces the points and condenser with a modern reliable ignition system
The Accu Spark electronic ignition is a complete unit that completely replaces points and condenser (requires no other parts ) . There is no wiring it only requires only 2 simple connections .Red to positive on coil ,black to negative on coil . Once fitted the points can be refitted at any time.
Posted: 28 Dec 2011 08:55
by Phathead
Hello,
I hope you find this video helpful.
http://www.youtube.com/watch?v=2lcx_Qr0KyM
I also ordered an Accuspark ignition for my TR7.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Neil_W</i>
Hi THE BOZZ,
Posted: 29 Dec 2011 17:09
by Pete
Thanks very much, the video shows the installation to be very clean and simple, albeit done in lab conditions, I'm sure the Bozz will oblige with a comprehensive illustrated report on his installation as promised !
I'm not getting negative feedback about any of the kits available, they all appear to work, so what's the drawback with the cheaper Accuspark, non adjustable dwell ?
Posted: 29 Dec 2011 20:49
I assume that the version for the AC distributor will be a little different. It is a little more inacessible in having the centif weights above the baseplate. They also do not come off to fit a trigger ring so I assume that the Accuspark will be of the lobe proximity type like the Pertronix.
Saab 9000 Stg 1
Saab 2.3 LPT Auto
Posted: 30 Dec 2011 14:51
by Pete
Thanks Alan and Neil, you spotted the snag, I overlooked it[:I]
In the picture kindly supplied by The Bozz, it looks like a trigger ring, and on closer inspection of the picture, it can be read from the instructions, 2nd Para "Due to the design of the Delco 300..." etc. to the point (sic), the distributor will have to be removed from the car to fit the trigger.
So, this is a disadvantage, compared to the Aldon you fitted and turns what looked like a < half hour job into half a day or more (the dizzy bolts have not been moved for 5 years !)
Decisions, decisions....
Using the formula :
[Reliability x Ease of Installation x Price Performance = Best Value Solution]
...I am non the wiser
1980 Canley DHC
Electronic Ignition. Advice Please
Posted: 08 Jul 2013 16:37
by g4zur
Good Evening All.
Just had a good old Krypton tune on my 2.0 1980 TR7.
Very pleased, running so much better, Garage chap suggested I got it changed to electronic Ignition, Advice would be much appreciated, Which one How much, Can I do it myself.
Many Thanks.
Best regards Gareth.
g.p.albrighton
Posted: 08 Jul 2013 18:16
by paulheritage
I fitted the AccuSpark Stealth kit which meant taking the distributor out but a fairly easy job. You have to take it out because you have to place a collar on the shaft and the D302 has fixed weights on top so the collar slides on from the bottom.
You also has to add a separate wire from the distributor and connect to wiring under the dash near steering column. I was able to do this so completely reversible if required. The extra wire is because our ballast resister is within the wiring not attached to the side of the engine.
The car was running rough before but now runs perfect and starts immediately and smooth.
I also replaced the coil and plugs from AccuSpark at the same time.
Cheers Paul,
1976 TR7 FHC (ACG 3115)
1977 TR7V8 3.9 FHC rally car (ACG 35005)
1980 TR7V8 3.5 DHC
www.TR7.co.uk
Posted: 09 Jul 2013 06:54
by Chris Turner
I have used both systems and they are both excellent, mpg is increased and starts much quicker. The Accuspark systems has the advantage on price and its now possible to buy one that can be fitted without removing the distributor.
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Sprint SJW 539S
TR7 Sprint SJW 545S about to start my last ever restoration.
TUD 682T
Posted: 09 Jul 2013 08:16
by supercass
So if I fitted one to my standard TR7 what sort of mpg increase could I expect? supercass
