sonscar wrote:Hopefully the new bush is correctly sized and does not require reaming in situ using an unobtainable jig (only joking?), Steve..
trsforever wrote:Hi, I think if you unlock the crank and rotate crank in direction of rotation a few turns it will come right, then recheck timing marks.
you will have to use extreme care fitting the front cover to avoid gasket damage now that the sump and head are on, I always do the front cover first.
Beans wrote:1+2 are from the back axle, though they seem to have been adapted to receive non original stops (larger holes were the (red) bump stops are fitted)
3+4 Brackets for the alternator, steel piece visible. Alloy bracket is fitted directly to the engine and hidden from view in this picture
5+6 gearbox mount
And the timing chain; the section between cam shaft and crank shaft should be in a straight line. The guide above the jackshaft is to set the "static" chain tension. Refer to the "book" for the correct timing procedure.
Beans wrote:As far as I know they were only fitted to the cars fitted with the 5-speed axle
