Electric fan turn on / off sensor switch issue
Re: Electric fan turn on / off sensor switch issue
Postby busheytrader » 04 Jul 2019 07:57
Back in the day with the 2.0L engine and the viscous fan, my temp gauge stayed at 1/4 all the time. I expect that a continuous airflow through the rad forces the thermostat to regulate the water temperature.
With the V8 and electric fan, I expect the 82c thermostat now spends most of its time fully open with the fan controlling the temperature instead. The gauge moves between a 1/4 and 3/8 when the fan kicks in around 90c. I've been driving the wedge in stop / start traffic through the recent hot weather and it clicks on and off regularly until it finds a constant moving road and isn't required.
Looking back at the standard two litre setup my viscous coupling eventually started to screech badly and had to be replaced. (My pals FHC had the same problem but wasn't replaced quickly enough as the fan launched itself in to the rad) :( . The replacement coupling was almost solid by comparison and noisy at high revs.
Postby Hasbeen » 04 Jul 2019 10:39
Same here. 1 was surprised at how much wind noise the new viscous fan made, it was so much louder than the old. 1 guess the old coupling had a fair bit of slip develop in it's 30 years of labour.
1 soon stopped noticing the wind noise, although don't know if that means 1 am used to it, or it is slipping more with work.
Users browsing this forum: No registered users and 20 guests
