Good morning John, Thanks for the advice, I think it may be some muck in the fuel, I went out at lunchtime and filled the car with petrol and it drove ok back from the petrol station to work and then home again. Still went up to 3/4 on the gauge, but drove ok.
When I pulled up at home the radiator started gushing water from the bottom right hand corner (where the bottom hose goes). I then took the radiator out last night.
A couple of weeks ago I changed all the fuel pipes as one had perished, but the garage (last night) has a smell of fuel again, so possibly fuel tank (now it is full) or the metal pipes that carry the petrol to the front of the car are leaking?
So because of the way I feel about the car at the moment, the fact that potentially I need to replace radiator, water pump, head gasket/head/timing chain etc, possibly fuel tank and pipes, the welding in the boot area, painting the underside and sorting out other bad paint areas, and I had intended to get a new set of carpets I don’t know what to do. Then there are the oil leaks, the fluid in the clutch reservoir is low and I guess the master/slave cylinder will need to be replaced, that if it doesn’t ruin the clutch first.
I love the car, I have always wanted one since I used to sit in them when they came out at my dad's garage and when he used to bring the demonstrators home from work. But it is impractical (2 seats) to go out in, it needs money spending on it, I don’t have any money.
I wanted to take it to Robsport to get the things looked at, but even if I change the radiator, I am a good couple of hours away so I don’t think it is viable to get it there as I would have to drive it.
Not a good day this morning.
Hope the rest of you have a good day. Regards Simon.
