Postby saabfast » 10 Jan 2019 20:56
When my clutch jammed it was one of the torque springs in the friction plate had broken and jammed between the pressure plate and friction plate. Luckily is was close to home so managed to get back in the gear it was stuck in.
Assuming yours is a 5 speed car you will need to get the pretty high to get the box out from underneath (as I did too) as the bellhousing is pretty big and the box is VERY heavy. (Assume the 4 speed has a similar size bellhousing but its a lightweight). I used two trolley jacks and made up a timber 'tray' to fit the bottom which a jack went under.
While it is out also check the shift extension bushes, shift rod oil seal, rear oil seal and maybe the pump, and check the crossmember mount has not turned to jelly.
