Prop shaft
lococars
Prop shaft
Postby lococars » 17 Mar 2017 14:19
I am re building a 5 speed TR7.Can anyone tell me which way round the prop shaft fits.It has CV joints both ends and one jointed end is longer than the other but it is not clear which way round it goes or does it not matter.
Regards.Steve
Re: Prop shaft
Postby REPLIC8 » 17 Mar 2017 15:58
This should help. :D
1981 Triton Green TR7 FHC (low mileage standard Solihull car)
1980 Inca Yellow TR7 FHC (awaiting restoration/upgrading)
Re: Prop shaft
Postby FI Spyder » 17 Mar 2017 17:24
I always thought the hole patterns were different. For future reference I always take a Dremel with a cutting disc and make a single notch across both surfaces at the front and two notches across the rear two surfaces so there is never any doubt even if they are painted while out.
lococars
Re: Prop shaft
Postby lococars » 17 Mar 2017 17:50
Thanks so much for the reply and photos.I have had a few issues with the re build because I bought the car fully dismantled.Most things are logical but I was struggling with this one.Thanks again.steve.
Re: Prop shaft
Postby busheytrader » 17 Mar 2017 18:40
FI Spyder wrote:I always thought the hole patterns were different......
They are different but you wouldn't notice until you refit the propshaft. I made a note that the wobbly bit was at the gearbox end so mine went on first time - lucky me.
Users browsing this forum: No registered users and 23 guests
