Hi all
I am in the process of taking out the gear box and have come to the part where the book tells me to loosen and remove the 4 bolts that hold the bias springs for the gear leaver.
Q Do i need to remove the 4 nuts or can i get away with just the 2 that are easily accessible from the cock pit. The top of the gear exchange.
I need to get the clutch going and it is stuck on to the flywheel plus is it an easy job to replace the back seal on the gear box as i will have it out and thought that it would be a good idea. It is leaking hahah. I know some of the answers that i will get.
Another question that i have tried to get an answer on is that i have looked around at different master and booster prv units and the best that i have seen that will fit is from a Volvo 960. So does anyone have an opinion on this.
Ta for any answers
Sunnie
