I've had a problem with the car for the last month.
When the car heats up and gets up to temp it has a tendency to stall.
I happens at or above 45 MPH or 2500 to 3000 RPM's
It first occurred after filling the tank with some Shell fuel but the
fuel looks clear and runs fine at lower speeds.
I've check fuel pressure, plugs, cap and rotor. I thought the issue was a bad cap chewed up by a bad rotor. After replacing both I'm still having the problem. Let me know what else I should check.
Thanks for any advice you can give.
1980 TR7 Spider DHC 2.0 Ac Delco Electronic Ignition.
