Bouncing Speedometer
Posted: 08 Jun 2015 19:28
I am hoping someone will have the answer to this annoying trait my car has !!
The speedometer jumps around randomly and by 10-15 mph at most speeds. I have tested the speedo head itself using an electric drill to drive it and it is as steady as a rock, so eliminating the speedo itself. Have fitted two new replacement cables, which seem ok for a few hundred miles but the shakes and jumping comes back .....grrrrrrr. The second cable I fitted was the shorter version as compared to the longer 'spitfire' one so it is the correct length. The routing is from the side of the gearbox drive and over the bell housing through the grommet and straight into the speedo head, so assume this to be correct.
Divine guidance and words of wisdom please before I resort to a box of matches as the cure !!
thanks
thanks
