Easy fix for heater levers
Posted: 06 Jun 2014 13:13
My heater blower lever was loose. I removed the panel to find that the lever is on a splined shaft. The lever is pushed over the shaft but is held on with only friction. My lever had worked partially off the shaft and had stripped the spline so it would not stay on very well. So I drilled a hole through the lever and into the spline and gave it a set screw. Works great and is nice and snug.
nick
'79 TR7 DHC
'76 TR7 FHC
nick
'79 TR7 DHC
'76 TR7 FHC
