<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
Here is my experience with two different cars. One is a dual ZS with a working FASD. The other is a dual SU with a manual choke. It is winter here and common temperatures are 30F.
The ZS carbed car has a working temp sensor and had a hot air tube to the intake. I removed it because it perished and disconnected the vacuum line for the cold air door. I see no difference in cold or hot performance with it removed.
The SU carbed car has round K&N filters with no hot air tube. It performs the same as the other car in hot and cold conditions after the choke is switched off.
[img][IMG]http://i615.photobucket.com/albums/tt234/nickmi/TR7%201975/Yellow.jpg[/img]
'79 TR7 DHC
'76 TR7 FHC
It's time for me to eat some crow. I have discovered that the above statement that I made is incorrect. Shortly after posting this I discovered some hesitation after the engine reached operating temperature. The hesitation was mostly in third gear at below 2000 rpm under a load. Also my idle was down around 500 rpm. I started thinking about Mildred's remarks and dug out my hot air hose and vacuum pipes. After reinstalling the hot air system I gave the car a good test and the hesitation is gone and the idle is back to 800. I'll be taking my crow fried with mashed potatoes.
Can someone tell me what the temperature range is on the airbox sensor?
'79 TR7 DHC
'76 TR7 FHC
