Steering rack dismantling.
clem2010
Postby clem2010 » 24 Jan 2016 19:08
Has anybody got any ideas on how to unscrew the pinion locking plug without
to much damage the only way i can see is to knock it round with a punch.
any ideas appreciated thanks.
Re: Steering rack dismantling.
Postby Hasbeen » 24 Jan 2016 23:35
Unfortunately, if you are talking about the thing described as the pinion retaining plug in my old manual Clem, which I assume you are, it tells us to use special tool 18G 1261.
I can't even find a picture or drawing of that, but it does appear that something special was once available.
From memory I think I used heavily modified, heavy duty expanding circlips pliers when I did a couple, about 12 years ago, but that is a very vague memory.
clem2010
Postby clem2010 » 25 Jan 2016 19:06
Hi hasbeen thanks for reply
My haynes manual mentions a special tool but like yourself i can not
find any details. The inside of the plug is smooth so making it difficult
for any tool to grip, just have to see if i can tap it round.
Thanks clem
Postby Cobber » 26 Jan 2016 01:12
I've not had to pull a rack apart, so I don't know what you'd need to do it with.
But if you could post a pic of the offending part, I'll probably be able to suggest a method of undoing it by drawing on my long and painful years of experience in industrial and automotive engineering. :lol:
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
clem2010
Postby clem2010 » 26 Jan 2016 20:04
Hi cobber
Thanks for reply managed to shift it with a small punch with not to much damage
now its out can see that it needs a tool with two prongs that will fit down around
the pinion may see if i can make something up to refit it .
Regards Clem.
Postby Cobber » 27 Jan 2016 00:52
Sounds like you need a face pin wrench.
They come in various styles and sizes
'80 Triumph TR7.
'98 MG-F.
Postby FI Spyder » 27 Jan 2016 15:01
That looks like an interesting tool to have. You can also tighten it up using the same technique you used to take it out. We used to do that all the time at IBM when there was no other option. Always better to have the right tool of course.
Postby Cobber » 27 Jan 2016 16:46
You can also get them to fit onto a torque wrench, though these are a bit hard to find.
'80 Triumph TR7.
'98 MG-F.
clem2010
Postby clem2010 » 27 Jan 2016 21:08
Had a look and you can get these on ebay look like they may well do
the job, handy tool to have anyway.
Thanks for all the help.
lgray001
Postby lgray001 » 16 Jan 2017 18:57
Here is the manual tools picture. It isn't much, but here it is anyway.
British Leyland Special Tool 18G 1261.JPG (11.31 KiB) Viewed 8650 times
