My New Disc Brake Back Axle
Postby john 215 » 02 Mar 2008 12:47
A few pictures of dics brake back axle i brought of Fleabay for a very fair price,in kit form but complete apart from a siutable handbrake cable.
Disc,poss standard front,box they come in has just Austin Rover on it and a part number,have to do some detective work.Adaptor plate and pads /caliper
Close up of caliper,Girling in make,but had a VW logo on it to me looks very similar to MK2 Golf GTI rear caliper [?]
A couple of picture of the adaptor plate mounted using the bolt holes used to retain the half shaft (3 in total)
Picture of a quick mock up of the set up.
The deal also included an axle,fitted with an alloy diff cover,i assume SD1,if someone goes to the trouble of doing that does it contain someting special LSD or different ratio [:D][:D] Will have to wait as mothers day here and real busy visiting in laws ect ect!!
All pictures taken in my conservatory,its great being divorced [;)]
Quick link to guys car who i brought the above off-
http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=6798
Cheers John.
Postby Odd » 02 Mar 2008 15:04
Yes John,
thats's an alloy SD1 rear plate - doesn't rust...
They seem to have plugged the position where the Watt link pivots with a bolt..?
terryjm1
Postby terryjm1 » 02 Mar 2008 15:07
I am very interested to know the origin of the disc. Thanks for the pictures.
Terry Merrell
St. Louis, MO
Postby john 215 » 02 Mar 2008 15:12
Hi Terry,
Will try and trace by part number on the box and post on here when i know,could poss be rear MGF i suppose look to thin to be front Maestro / Montego.
Cheers John.
ggreen
Postby ggreen » 02 Mar 2008 19:24
Are the caliper mounting brackets aluminum or steel ? Be interested as to what hand brake arrangement you come up with.
jeffremj
Postby jeffremj » 02 Mar 2008 20:04
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Close up of caliper,Girling in make,but had a VW logo on it to me looks very similar to MK2 Golf GTI rear caliper?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I agree. I remember it from when I changed the pads on our old GTI Mk2.
Postby john 215 » 02 Mar 2008 20:16
Hi
Caliper mounting are steel and appear to be very well made.
The adaptor is approx 5/16" or 8mm thick,the center hole is tapped the outer to 2 not,gives a perfect fit and 3 hole location.
As for handbrake cable,there in lie's the fun in setting something like this up [;)] Can see me walking around a few VW swap meets with a caliper in one hand a tape measure in the other [:)]
Cheers John.
Postby Rich in Vancouver » 02 Mar 2008 21:02
John,
I don't suppose that we would be able to persuade you to do a simple dimensioned drawing of the bracket would we?[:D]
Rich
Postby john 215 » 02 Mar 2008 22:06
Hi Rich,
Would be glad to,just got to work out how to put it on here [?] Will have a word with my teenage daughters tomorrow they a bit more computor savy than me. If that beats me [B)] more than happy to use the old fashion way and post you a life size drawing.
Postby jclay (RIP 2018) » 02 Mar 2008 23:29
John,
Send me a jpeg of PDF of the drawing and I will post it to my download site so everyone can have it.
Postby Rich in Vancouver » 03 Mar 2008 00:49
Thanks John,
Teenagers are invaluable aren't they. I've got a couple of teenage daughters myself, or as we like to call them, "The IT Department".
That setup could be just the ticket for me. As well as for my 7 I am working on a 4 wheel disc setup for my ZA Magnette and the MGA Twin-Cam rear calipers I bought on E-bay turned out to be from an XK150.
This would be an easy solution...if not quite period![:)]
Rich
Postby UKPhilTR7 » 03 Mar 2008 12:09
<b><font color="blue">From looking at this, would you be able to make the bracked yourself, given the right dimentions and then use a spare set of TR7 calipers that you have knocking around?
I do so happen to have these spare calipers in my garage and a rear axel knocking around that I could use as a mock up. From the questions about the dimentions I take it that I am not the only person to have these kinds of thoughts?[?]
I would however, look at making the Caliper mounting bracket out of a solid square or make the end bits a little thicker, due to the pressure that will be on it when the breaks are put on.</font id="blue"></b>
Postby Rich in Vancouver » 03 Mar 2008 14:04
The only problem with using TR7/8 calipers is that bthey have no provision for a handbrake.
Rich
Postby john 215 » 03 Mar 2008 18:39
Having consulted the <u>'I.T Department'</u>[:D] [:D] they kindly showed me which things to hi light and what to click onto BUT refused to do it for me [V] as they found it far to funny watching me than doing it themselves [:D] i am sorry for the roughness of this but the dimesions are resonably accurate give or take a mm or 2 Anyone wishing to make this would poss adviced to make a mock up out of wood or MDF a lot easier to work with [;)] and then check fitment.
As well as the caliper, almost certain is MK2 Golf GTI, you will need the carrier to bolt too.
Cheers John<u></u>
Postby Shauniedawn » 03 Mar 2008 21:40
Why not dispense with the handbrake mechanism and cable completely and put another master cylinder inline with the rear brakes and have a hydraulic setup?
I've done this modification on both a Mk2 and an E-Type Jag a lot of years ago to get around their terrible handbrake mechanisms. Works a treat.
Shaun
Users browsing this forum: No registered users and 277 guests
