Need length of 5 speed transmission.
Posted: 26 Feb 2008 20:35
Can someone measure the 5 speed transmission for me?? Not having any luck finding one locally out of a car.
The specific dimension that I am looking for is the length of the extension case on the LT177. The extention case is the alum housing which is mounted to the rear of the main case. I am not asking about the shifter remote. The extension case is mounted in between the main case and the shifter remote.
On the R380 the extention case is 4.6" long at the top. I need the length of the LT177 extension so I can compare.
Also note that on the R380 the shifter lever is 9.25" away from the mounting face of the remote. On the TR8 remote the center of the shifter lever is 8.69" away from the mounting face. The TR7 shifter remote is not the same as the TR8.
Randall
Randall
