Wiper Switch Rebuild
Posted: 20 Feb 2008 05:49
by Rblackadar
I'm rebuilding the wiper and turn signal switches for my baby and I have repaired the poorly constructed mechanisms back to good as new. Well better actually. They used rivets on fastening the wiper switch contact board to the the main turn signal braket which forced the plastic to break overtime....Real dumb! Now I have all the contacts cleaned and ready to go but there's one thing... there's a spring inside the mechanism thats used for a a contact bridge, and for the life of me, I can't figure how the hell it goes back in to make to make the correct complete circuits. If anyone knows or you have one lying around, can you describe to me how it's positioned in there? Thanks!
Posted: 20 Feb 2008 10:08
by Henk
I've the same problem, the contactbridge is for the one time wipers.
but i don't know how it must be placed.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Posted: 20 Feb 2008 18:36
I wish I could help but my spring pinged across the garage floor when I took my wiper switch apart!
After owning the 7 for 20 years the wipers would barely make it across the screen. After renewing the motor, taking apart the whole rack and spindles, cleaning all the relevant contacts in the loom and checking out the wiper switch I finally found the problem. One of the muppets who had owned the 7 before me had cut the wires to the switch, then reconnected them by baring and twisting them together before wrapping everything up in insulation tape. A proper repair brought the wipers back to life immediately.
BUT. The wipers now only have one speed across both settings until someone lets me know the proper positioning of this spring. Then again I'll need an extra set of fingers to keep that spring in place when putting that switch back together. No wonder a new indicator stalk / switch is £50.00 + vat.
Oh yes, the parking switch that came with the recon motor takes about 5 cycles before it finally parks the wipers!
Cheers,
