What is the purpose of shear bolts on the steering
92rrrandall
Postby 92rrrandall » 20 Feb 2008 02:59
What is the purpose of shear bolts on the steering column?? There are two shear bolts there and also two smaller shear bolts on ignition switch/lock. My guess would be that it has something to do with theft prevention or to make the steering column collapse in an accident.
Randall
Postby Rich in Vancouver » 20 Feb 2008 03:51
The idea was to prevent someone from removing the steering lock from the column. If they could do so they could then just hotwire the car and drive away.
Rich
Postby Hasbeen » 20 Feb 2008 05:17
Rich, I must disagree with you on this one.
I believe they had a realy nasty young sod of an engineer at
Triumph.
He thought it was funny to make a bunch of silly old farts, crawl
around in the bl@@dy foot wells of 25, to 30 year old TR7s, to drill
the bl@@dy things out, when they could have unbolted them quite
easily, with normal fasttenings.
If I could find out who specified the bl@@dy things, & I could get
at him, he would suffer a serious injury, & what's more, I don't
like them, incase you hadn't guessed.
Postby Rich in Vancouver » 20 Feb 2008 14:01
[:D][:D][:D][:D][:D]
There are actually a couple of ways to remove them that are easier than drilling.
1/use a sharp center punch, place it to one edge of the shear bolt head and gently tap it in a counterclockwise direction to loosen.
2/Using a Dremel tool cut a slot in the head to undo with a slot screwdriver.
Rich
Postby john 215 » 20 Feb 2008 18:32
Hi Hasbeen,
That will be the same 'young sod' that went on to design the clip that holds on the wheel cylinder then [:(!]
Cheers John.
dave.c
Postby dave.c » 21 Feb 2008 18:22
I hope you dont mean the brake cylinder as ive just bought a pair off E-bay was going to be my next job
better not make any plans then!
Its hard not to be big headed driving itImage
Postby john 215 » 21 Feb 2008 20:12
Hi Dave,
Cylinder itself no problem [:)] Just the ssstttttoooooooopppppppiiiiddd clip that retains it, screwdriver normaly slips off whilst you trying to lever on clip, the screw driver then digs its way into your finger [B)] the said clip then flys off to the dark corner of your garage, you know the one under your work bench never to been seen again [V]
Cheers John.
Postby FI Spyder » 22 Feb 2008 01:52
I've put hundreds of these c-clips on with no problem (both straight and curved) although they were lots smaller (in various office products). They could be levered on with appropriate sized screwdriver depending on their size. Now I've taken these off but not put them back on yet but based on their size I can see it would be very difficult to lever them on with a screw driver. I would try starting them with a screw driver but once it's caught in the groove I'd tap it in with a flat tipped punch and a rap with a hammer. Be warned it's imperative that the punch has to be centred, if it's not the clip could go flying. Won't be in position to do it for a couple of weeks but I thought I'd post this now.
Ferris
Postby Ferris » 22 Feb 2008 02:49
I gave this particular sod of an engineer a name - Nigel Screwright.
Every time I run into something like this, well, ol' Nigel got me again! It makes me feel better to actually curse his name.
Image[/img]
Kevin Anderson
1980 TR7 DHC
1974.5 MGB GT
1990 Jaguar XJ40
Postby Rich in Vancouver » 22 Feb 2008 04:38
"Nigel Screwright" I like that[:D]
My C-clips were on the verge of being pooched and the new cylinders didn't come with any so I popped down to our local marine hardware store and invested in some before even attempting the job. The new clips had lots of spring and went on without any trouble. I tried one of the old ones and it folded like a bad hand.
Rich
dave.c
Postby dave.c » 02 Mar 2008 10:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Hi Hasbeen,
Cheers John.
Well I can certainly agree with you after trying to find where it sprung off to each time but managed to do it only to get rained off whilst bleeding them.
All jobs can be sh** if you have to rely on the weather
ATB Dave
Users browsing this forum: No registered users and 217 guests
