Headlamp unit overhaul
Posted: 23 Oct 2021 11:15
Just getting into the overhaul of my headlamp units. I will be fitting Quadoptic halogen headlamps as an upgrade. Decided to source new backing bowls, inner bowls and outer retaining rims as they are relatively cheap and will save time trying to refinish the tired and corroded old ones. I have retained the original mounting plates (YKC682 and YKC683) as these seem to be unavailable and will refurbish these. I am thinking of adding relays to the main and dip beam circuits in order to avoid high current running through the headlamp switch. Not sure why Triumph didn’t do this; probably those pesky bean counters I expect. All the linkages will be cleaned up and lubricated on reassembly. Any tips on the correct lubrication for all the various parts would be welcome.
Thanks, Rich.
Thanks, Rich.
