Triumph TR7 Hazard Lights Problem
Posted: 03 Sep 2017 22:01
by Monkeyzak
My hazard lights sort of flick on and off really quickly and would not pass an MOT. I have a spare indicator relay with an earth in a box somewhere. Is this the same thing as the hazard relay? Thought id try the relay first then strip the switch. Anything else I should check
The car is getting used most days now. I love it. The list of winter jobs is getting bigger. For a car that's been off the road 20 years. It's been great since me and my mechanic mate got it running in May.
Re: Triumph TR7 Hazard Lights Problem
Posted: 04 Sep 2017 09:40
by rugbyref1
Yes the flasher unit is near the fuse box (looks like the one for the indicator)
Posted: 04 Sep 2017 12:19
by Howard_B
Have you checked all the actual bulbs are flashing quickly as well? Check the earths carefully because this will effect the flash rate.
Its also possible that the main flasher has been changed to an electronic unit, but the hazard flasher is still the original thermal device which is much less reliable. Another possibility is that someone has changed the bulbs to LED's?
Posted: 04 Sep 2017 20:57
by Monkeyzak
The indicators are fine. They all flash ok. Definitely not got led
I'll try the flasher unit when I get a chance this week. How come earth the new one? A self tapper somewhere?
Posted: 04 Sep 2017 21:24
Monkeyzak wrote:My hazard lights sort of flick on and off really quickly ...
That usually points to an earth problem
Posted: 04 Sep 2017 21:55
by Monkeyzak
I'll have a go and report back. Thanks
Posted: 04 Sep 2017 22:41
by supercass
To me this indicates that an incorrectly rated flasher unit has been fitted to the hazards. supercass
