LT77 GEARBOX OIL PUMP
Posted: 29 May 2017 22:51
Having got a problem with 5th gear synchro(crunching on the change up) I have decided to use the box that was in my 84 SD1 2.0.
It was perfect when taken out in 1993(no swarf on drain plug when drained - 43,000 miles) and has sat in the garage ever since.
I'm going to go over it and fit new gaskets and seals and thought about changing the gears in the oil pump.
There are some for sale that are all steel rather than fibre like the original.
My question is,has anyone had any experience of these or should I stay with the original type?
Many thanks in advance.
