Soft top press stud fitting tool
Posted: 18 Apr 2017 14:23
by andyf
I am replacing the hood press studs but don`t want to have to remove the top to use one of those hammer type of drifts, is there a pliers type of thing available that you can use? I have tried online searching but the results are not very clear whether they would work. What have others used and could you point me in the right direction?
Ta in advance.
Re: Soft top press stud fitting tool
Posted: 25 May 2017 12:12
by simps
I bought a leather punch off Amazon for making a hole in my belt:
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1not sure if it would work on a hood, but at a fiver it must be worth a try???
Posted: 25 May 2017 14:34
by darrellw
There is a pliers type that you can get at a fabric store, but they are often pretty weak, so I would not recommend them for a soft top. I've seen types that fit over vise grips, and there are various heavier duty types.
Here is perhaps the very best, but pricey:
http://www.sailrite.com/Pres-N-Snap-Fastener-ToolI would avoid this type:
http://www.michaels.com/heavy-duty-snap ... 7CD006967SThis one looks sturdy and not too expensive:
http://www.iboats.com/Snap-Tool-Kit/dm/ ... oC6PDw_wcB
Posted: 25 May 2017 18:41
by darrellw
I finally found the version that goes into your vise grips. I think this is the best option if you are only doing a few. If you where doing more, I would invest in one of the higher-end options:
https://www.amazon.com/dp/B000MQYP58?psc=1
