Page 1 of 3
Vehicle Identification Plate
Posted: 02 Mar 2017 23:54
by UKPhilTR7
A few years ago, the doors on my TR7 were replaced. This was due to the bottom of the old doors going rotten. The new doors were cleaner and would have been a lot less work than trying to fix the old ones. So they were replaced and the old once scrapped.
When the old doors were scrapped, the bits needed were taken off them and they went. At the time I forget to take the Vehicle Number plate off the passengers side door. I have the VIN plate on the turret still, but not the original Vehicle Number plate.
Thankfully the VIN is there. So is there a way that I can locate the Vehicle Number and then get a new plate marked with this number, so I can put it on my car?
Re: Vehicle Number Plate
Posted: 03 Mar 2017 01:55
by supercass
Is this the same as the body number or body in white number? supercass
Posted: 03 Mar 2017 02:11
by UKPhilTR7
To tell you the truth I am not sure.
Posted: 03 Mar 2017 02:18
by supercass
Speke, Canley or Solihull? supercass
Re: Vehicle Identification Plate
Posted: 03 Mar 2017 06:20
by rugbyref1
To clear this up .... there are three plates on UK cars and 4 on Australia (& some other export) cars the common ones are :
- Frame number (pre fitment of engine and trim)
- Body number (after spraying)
These two are both slim tags and will be found in the engine bay (normally on the turret and front slam panel)
Common again is the VIN plate (variations of this depending on year / factory) - this is a black and silver plate which on early car is on the door (& the one i assume you are missing)
TR7 Vin.jpg (44.38 KiB) Viewed 7575 times
Some export also have an additional plate in the engine bay. TR7 export plate :
TR7 export plate sm.jpg (53.67 KiB) Viewed 7575 times
Some countries also have a plate near the windscreen with the VIN on it :
North American windscreen tag.jpg (149.02 KiB) Viewed 7575 times
Posted: 03 Mar 2017 10:46
by sydney.wedgehead
I was told by a local that the Australian "TR7 export plate" you reference was fitted here at Zetland in Sydney.
I am not sure of the veracity of this statement.
Posted: 03 Mar 2017 11:25
by rugbyref1
Makes sense ... this is what went on the german cars
Posted: 03 Mar 2017 11:43
by Cobber
sydney.wedgehead wrote:I was told by a local that the Australian "TR7 export plate" you reference was fitted here at Zetland in Sydney.
Yeah that's right, "Compliance plates" are fitted here, cars can't be registered here without one.
Posted: 03 Mar 2017 11:45
by UKPhilTR7
This is the one that I have onthe passenger side turret.
This is the one that need to get with my details. It is the one on the passenger door:
Posted: 03 Mar 2017 11:56
by sydney.wedgehead
Phil,
You should talk to Beans (Theo) about reproducing the missing plate, as he's done amazing work reproducing plates for the resto of his early orange FHC.
Owen
Posted: 03 Mar 2017 14:00
by supercass
UKPhilTR7.
Is it the car pictured in your signature photo that you require the plate for? supercass
Posted: 03 Mar 2017 14:46
UKPhilTR7 wrote:This is the one that I have onthe passenger side turret.
That's the correct type of VIN plate for a Canley or Solihull car this side of the pond :roll:
But should always be accompanied by a VIN number stamped in the chassis or bodywork (for cars with unitary bodywork)
Posted: 03 Mar 2017 14:52
For the anoraks, anyone know what VIN number this is ...
Posted: 03 Mar 2017 16:53
by supercass
If it is a later U.K. car afaik it would not normally have a plate on the door though the holes to place the plate may still be present. The VIN plate would go on the turret and the VIN would also be stamped in the gutter at the side of the boot. Afaik some but not necessarily all later cars may have a body number on a small plate adjacent to the fan shroud on the headlight panel. The body number has no direct relation to the VIN. A seemingly unrelated number may be present on the door aperture between the hinges. supercass
Posted: 03 Mar 2017 17:43
by rugbyref1
Beans - it's one of the last ones issued
