Vehicle Identification Plate
Postby UKPhilTR7 » 02 Mar 2017 23:54
A few years ago, the doors on my TR7 were replaced. This was due to the bottom of the old doors going rotten. The new doors were cleaner and would have been a lot less work than trying to fix the old ones. So they were replaced and the old once scrapped.
When the old doors were scrapped, the bits needed were taken off them and they went. At the time I forget to take the Vehicle Number plate off the passengers side door. I have the VIN plate on the turret still, but not the original Vehicle Number plate.
Thankfully the VIN is there. So is there a way that I can locate the Vehicle Number and then get a new plate marked with this number, so I can put it on my car?
supercass
Re: Vehicle Number Plate
Postby supercass » 03 Mar 2017 01:55
Is this the same as the body number or body in white number? supercass
Postby UKPhilTR7 » 03 Mar 2017 02:11
To tell you the truth I am not sure.
supercass
Postby supercass » 03 Mar 2017 02:18
Speke, Canley or Solihull? supercass
Re: Vehicle Identification Plate
Postby rugbyref1 » 03 Mar 2017 06:20
To clear this up .... there are three plates on UK cars and 4 on Australia (& some other export) cars the common ones are :
- Frame number (pre fitment of engine and trim)
- Body number (after spraying)
These two are both slim tags and will be found in the engine bay (normally on the turret and front slam panel)
Common again is the VIN plate (variations of this depending on year / factory) - this is a black and silver plate which on early car is on the door (& the one i assume you are missing)
TR7 Vin.jpg (44.38 KiB) Viewed 7565 times
Some export also have an additional plate in the engine bay. TR7 export plate :
TR7 export plate sm.jpg (53.67 KiB) Viewed 7565 times
Some countries also have a plate near the windscreen with the VIN on it :
North American windscreen tag.jpg (149.02 KiB) Viewed 7565 times
Christopher
sydney.wedgehead
Postby sydney.wedgehead » 03 Mar 2017 10:46
I was told by a local that the Australian "TR7 export plate" you reference was fitted here at Zetland in Sydney.
I am not sure of the veracity of this statement.
Postby rugbyref1 » 03 Mar 2017 11:25
Makes sense ... this is what went on the german cars
Christopher
Postby Cobber » 03 Mar 2017 11:43
sydney.wedgehead wrote:I was told by a local that the Australian "TR7 export plate" you reference was fitted here at Zetland in Sydney.
Yeah that's right, "Compliance plates" are fitted here, cars can't be registered here without one.
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Postby UKPhilTR7 » 03 Mar 2017 11:45
This is the one that I have onthe passenger side turret.
This is the one that need to get with my details. It is the one on the passenger door:
sydney.wedgehead
Postby sydney.wedgehead » 03 Mar 2017 11:56
Phil,
You should talk to Beans (Theo) about reproducing the missing plate, as he's done amazing work reproducing plates for the resto of his early orange FHC.
Owen
supercass
Postby supercass » 03 Mar 2017 14:00
UKPhilTR7.
Is it the car pictured in your signature photo that you require the plate for? supercass
Postby Beans » 03 Mar 2017 14:46
UKPhilTR7 wrote:This is the one that I have onthe passenger side turret.
That's the correct type of VIN plate for a Canley or Solihull car this side of the pond :roll:
But should always be accompanied by a VIN number stamped in the chassis or bodywork (for cars with unitary bodywork)
Postby Beans » 03 Mar 2017 14:52
For the anoraks, anyone know what VIN number this is ...
supercass
Postby supercass » 03 Mar 2017 16:53
If it is a later U.K. car afaik it would not normally have a plate on the door though the holes to place the plate may still be present. The VIN plate would go on the turret and the VIN would also be stamped in the gutter at the side of the boot. Afaik some but not necessarily all later cars may have a body number on a small plate adjacent to the fan shroud on the headlight panel. The body number has no direct relation to the VIN. A seemingly unrelated number may be present on the door aperture between the hinges. supercass
Postby rugbyref1 » 03 Mar 2017 17:43
Beans - it's one of the last ones issued
Christopher
Users browsing this forum: No registered users and 276 guests
