TR8 Brake Booster Problems
Posted: 10 Dec 2014 20:22
by RJS
Car is 1980 factory TR8 Carb.
When I push in the brake pedal, there is a continuous hissing sound. Takes a lot more pressure to stop the car (no more power for the power brakes). If car is idling when I press the brakes, RPMs go up a little when I hear the hissing sound.
Obviously there is a problem with the brake booster. I will have a helper in a few days to dig deeper (I cannot press the pedal and mess with the booster at the same time).
Is this something I can rebuild? If yes, where can I get a rebuild kit? What is involved with rebuilding a booster?
If I should not try to rebuild, where can I find an affordable brake booster replacement?
Thanks,
Rob
Posted: 10 Dec 2014 23:14
by Peter Nuss
Don't really need a helper to dig deeper. You have a bad brake booster. I can tell you exactly what's leaking but, it won't matter much. It needs to be rebuilt.
You can find a rebuid kit on ebay or contact S&S in the UK. Probably some others also.
For $20 a year, join the TWOA. Some blowhard wrote a tech article on how to rebuild your booster in your own garage a few issues ago. Where to send the booster for replating etc.
You can also buy a rebuilt one from the two US suppliers of TR8 stuff for around $300 plus shipping two ways. But, it will be painted black instead of cad plated. I thinking it's on a exchange program, so you loose your booster for one that's maybe not so nice as a dry climate one.
Good luck with your project
TR8
Posted: 11 Dec 2014 04:39
Check the hose first. It could be split particularly near on one of the fittings at either end, so sucking air, & that is the sound you're hearing.
I have heard hoses sucking air a couple of times, but have not heard any his from a booster even when the diaphragm was split, although this could depend on how big the split is. A big split would probably not be noisy.
How is the thing running? It should be out of tune if one inlet is getting air after the throttle butterfly.
Posted: 11 Dec 2014 09:15
by jclay (RIP 2018)
Woody did mine and redid the cad plating. Here is the one that Woody did for my TR7:
Picture at bottom of page;
http://www.jclay.me/jclay/Big_Brakes_2.html#6
Clay
Posted: 11 Dec 2014 12:53
by RJS
Thanks for the info guys.
Would it be smart to rebuild the brake master cylinder at the same time, or should I leave it alone (if it aint broke, don't fix it).?
Rob
Posted: 11 Dec 2014 13:31
by jclay (RIP 2018)
Get a brass sleeve installed!
http://www.applehydraulics.com/brakes.htm
Clay
Posted: 11 Dec 2014 17:28
by kstrutt1
If it is the same as the 7 the seal between the master cyl and the servo is often the culprit, this can just about be done by undoing the bolts and pulling the cyl forward.
Kevin
Posted: 19 Jan 2015 19:16
by RJS
Quick update.
I got the rebuild kit from S&S and rebuild the brake servo today. Everything is good again.
Thanks Peter for the advice. I did finally join the TWOA. The article on rebuilding the servo was very helpful (even if the writer was bit of a blowhard).
Rob
