How can I tell if still any good?
Posted: 05 Oct 2014 11:17
Today, I got around to taking off the front springs off the struts and taking them all apart with the shocks out. Now I can see the bits that I think it is time to replace and the other bits that with a coat of paint or grease, should be OK.
When I took off the Strut Insert & Sprint section, both were as dry as a bone. No grease on the flat washer, the cone or the thrust washer. I would of thought that there would of needed to have some amount of lube??
So my question is, with the shocks how can I tell if they are still OK or if they should be replaced? When I pushed and pulled them they both seemed the same amount of resistance.
