I run 28to30psi for both 195 60 14 and 195 50 15. Personally I prefer the 60 profile for handling, comfort and aesthetics.
fuel efficiency , V8 wedge? I think tyre inflation will be white noise on your mpg graph -negligible. Ignition, carb settings and your right foot will have a much larger effect on mpg but smiles per mile with a V8 is priceless.
