Footwell fresh air vents
Postby dursleyman » 21 Jan 2014 16:07
There has been some chat on the TR7/8 list about the fresh air vents fitted on some cars in warmer climates. They seem like a good idea and are a relatively easy retro fit but are totally NLA.
Ted Schumacher does some stainless reproductions which he sells at $104.94 (about £63.75) plus postage. Just wondering if I might try some.
1980 TR7 Sprint DHC
trekcarbonboy
Postby trekcarbonboy » 21 Jan 2014 17:00
My car has them as original fitment. I can say that they do move the air quite well. First cold day in the fall is when they are most noticeable. Then I find myself at a stop light with a gear shift in my ribs as I try to close the passenger side one. [;)]
Not sure I'd bother fitting them to a DHC though.
Craig '75 2.0 FHC
kstrutt1
Postby kstrutt1 » 21 Jan 2014 17:07
My v8 dhc does get uncomfortably hot in the footwells on the few hot days we have, I would consider fitting them but not at the price above, there are various surface mounting vents avaliable from the likes of car builder solutions I might fit these instead.
Kevin
Postby john 215 » 21 Jan 2014 17:22
Hi Russ,
I did email Ted a while ago and he was out of stock, new stock due in next week, I going to get a set, then hope and pray we get a summer to make use of them !!
Got some trims of Steve up at S & S Prep, wrong colour but got some blue leather trims without the cut outs to strip and cover them, or use as templates.
jeffremj
Postby jeffremj » 21 Jan 2014 17:35
I imported a pair about 20 years ago [8D]
Postby DNK » 21 Jan 2014 17:42
There is suppose to be trim there?
Stick a Wedge In It
trekcarbonboy
Postby trekcarbonboy » 21 Jan 2014 18:00
Craig '75 2.0 FHC
Stevie P
Postby Stevie P » 21 Jan 2014 18:01
Any one got a pic of where these should go, connect, look like?
Thanks,
supercass
Postby supercass » 21 Jan 2014 18:06
Dursleyman, don't forget there will be import duty, VAT, and a fee on top of that. supercass
Postby dursleyman » 21 Jan 2014 19:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by supercass</i>
Yes I knew there would be something to add, anyone any ideas how much?
whitenviro
Postby whitenviro » 21 Jan 2014 19:33
Jeez, DNK; I should have charged you $150 for those vents I pulled from the car in Vancouver! After all, original equipment has got to be worth more than aftermarket stuff[:D]
They did have a trim panel around them in that car, but the fiberboard was soaked and they weren't in good condition. I should have taken one as a template so you could cut your own.
[/img]
Postby DNK » 21 Jan 2014 19:41
Yes, I didn't want to buy Teds as I will powder coated them.
I could use a cardboard template.
If I remember right I have solid ones in my stash "O" parts.
The pic really helps
Stick a Wedge In It
Postby silverseven » 22 Jan 2014 00:00
The footwell vents are one of my favorite features , they move a nice amount of air around the footwells and are especially enjoyable on longer drives when you want the comfort of the roof up and the music on.
I open mine up as soon as the windows go down in the spring and only close them up once the cooler weather hits in the fall.
Postby DNK » 22 Jan 2014 00:47
Somebody profiting on a spare pair with the shark feeding frenzy
Stick a Wedge In It
Postby john 215 » 22 Jan 2014 04:33
Hi Russ,
There are sites that will calculate the amount of VAT and inport duty, not sure how accurate they are though, example such as -
http://www.dutycalculator.com/new-impor ... lculation/
Users browsing this forum: No registered users and 363 guests
