Door window weather seal...
Posted: 20 Jul 2013 13:16
by Duplio7
Hi Guys, I just spent best part of an hour fitting the door window weather seal. Is there an easy way to do this?
This never happened to the other fellah...!
Posted: 20 Jul 2013 14:22
I've only done it with the window/door card out. You can then press on the weatherstrip clips with your fingers. This also gives you the opportunity to clean and grease the window winder, replace/inspect/reposion/re-install the window felt guides, adjust guides to prevent window cocking, remove quarter window frames for repainting with trim paint, repair broken tabs on door light and clean it's contacts, remove clean and grease, door latches, replace torn/missing outer latch gasket, install missing rubber bumper that keeps outer door latch even, sprat Waxoil into lower door seams.
Posted: 20 Jul 2013 14:42
by darrellw
I have this tool, last one on the page:
http://www.originalduplicates.com/tools.html
Would be easy to make, it has a magnet to hold the clip. I got it for my TR4A, but works great on the TR8, too. Just press the seal down tight, then use the tool to pull the clip up into place.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Posted: 20 Jul 2013 17:13
by gaz
If you get the special tool and its not magnetic then dip the end in grease that'll hold the clip on and if your using new clips then just open them out slightly with a screwdriver first.....
1981 DHC 2.0 Litre
1980 DHC pedal car
Posted: 20 Jul 2013 20:36
I made one of those tools out of a 30mm wide strip of galvanized stripping, with the "handle" end wrapped with 5 or 6 thicknesses of masking tape.
I use a bit of blue tack to hold the clips in the tool.
