Clutch Master Cylinder Rebuild
troydeon
Postby troydeon » 04 May 2013 13:59
Finally getting to my leaky clutch master cylinder. Got it out with no problems, but now it won't disassemble. Got the clip out but the internal piston and spring do not come out, am I missing something... maybe I should have just got a rebuilt one...
Troy
1980 TR7 DHC
Postby Hasbeen » 04 May 2013 14:24
Try compressed air applied to the outlet fitting.
Postby busheytrader » 04 May 2013 15:47
I've rebuilt mine a couple of times now, no issues taking it apart, although removing the circlip was fiddly.
No scoring in the cylinder, just the rubber perishing.
Image[/URL]
troydeon
Postby troydeon » 04 May 2013 16:48
Thanks all, I went ahead and read the manual I had, I guess I should have started there. It recommended the compressed air also. I don't have compressed air but a few bumps against cardboard on the garage floor got it out...
From there straight forward. It was filthy! Had a little trouble bleeding the system, but finally got it fine after closing up the system and pumping it up vigoursly, maybe I should have started that way.
The systems been working fine - there is a new hose and the slave looks new so I think that now that I took care of the leaky master it should be fine for a while.
The kit was easy to use.
Troy
1980 TR7 DHC
trekcarbonboy
Postby trekcarbonboy » 05 May 2013 09:52
Yep Troy, the cardboard on the floor worked for me last week too. [:)] A large socket on the end helps too but I'm a bit late with that info.
Not sure where you got the hose but if you got it from Vic Brit they are soft and will expand under pressure (unless its the ss one). So if you notice any problem engaging the clutch,that's it. You can visibly see the hose expand! [V] I had trouble with mine so went back to the original one.
Craig '75 2.0 FHC
Postby FI Spyder » 05 May 2013 13:22
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Not sure where you got the hose but if you got it from Vic Brit they are soft and will expand under pressure (unless its the ss one). So if you notice any problem engaging the clutch,that's it. You can visibly see the hose expand! [V] I had trouble with mine so went back to the original one.
Me too! While I can't say I saw it expand, I could feel it expand by holding it.
Users browsing this forum: No registered users and 119 guests
