Door Courtesy Lights?
Posted: 08 Oct 2012 21:00
by fencible39
Does anyone know what year they were introduced? Was it 1978?
Dave Orcutt
1977 FHC Automatic
1978 FHC 5spd (Deceased)
2007 Hummer H3
Posted: 08 Oct 2012 21:15
by TR Tony
Well as with all things BL the dates may be a bit fluid, but officially they door lamps replaced the roof lamp from chassis number ACG25001, which was June 77.
Posted: 08 Oct 2012 23:14
by nick
Interesting. I always thought the door lights were introduced with the DHC.
nick
'79 TR7 DHC
'76 TR7 FHC
Posted: 09 Oct 2012 18:53
I thought they were introduced when the tasteful range of check / tartan interiors appeared.......[:)]
Posted: 09 Oct 2012 22:34
by rgsSpider
That's one of those pieces I wish there was a modern upgrade for. I've got the chrome ones. I've seen some that are just stationary lights that look similar. I took mine out and did the fix that someone here mentioned, using the ends of zip-ties to reinforce the tabs.
Randy
Posted: 09 Oct 2012 23:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rgsSpider</i>
That would be me. I believe they are available now in black rather than chrome. They are also available as none movable versions. The only thing bad about the movable version is that un daylight it is possible to bump them so they are on without noticing and draining battery over longer period.
Here's what Randy is referring to.
Posted: 10 Oct 2012 00:26
by V8Wedgehead
Approximately March to May 1977
Michael
1980 RALLY TR8 FHC #0020
Posted: 11 Oct 2012 04:16
by rgsSpider
Thanks FI! I thought it was you but didn't want to credit the wrong person. Very good tip too!
Randy
