Track rod end replacement
Posted: 06 Sep 2012 13:24
by john
Ok guys time to learn a new trade or operation so what is the best method to replace track rod end as the ball joint dust cover is split and Mr MOT man doesn't like it [B)]
Posted: 06 Sep 2012 13:38
by Workshop Help
Provided the joint has not seized and can be reused;
Buy a new dust cover.
Remove the nut from the bottom of the joint.
Separate the joint from the steering arm.
Remove the old & install the new dust cover.
Reinstall the joint into the steering arm and tighten the nut.
Wash your hands and say, "What a good boy I am!"
Posted: 06 Sep 2012 13:45
by Neil W
Quite a painless operation as long as you don't hit your hand with the large hammer.
1. Put front on axle stands so both wheels are off the ground.
2. Unscrew the lock nut on the steering rack rod - there is a flat on the end if you push back the Steering rack gatter or use mole grips to hold shaft.Might need small blow lamp on nut if tight to heat it up.
3. Measure distance of thread showing so you can screw it back on at same distance later on.
4. Undo nut on top of track rod end - & thump up / down on track rod end as I assume you will replace the complete unit.
5. It will pop out then unscrew from steering rack.
6. Fit new one on Steering rack to same distance - pop ball joint back in the cleaned hole & tighten to correct torque.
7. Tighten lock nut on steering rack & put new cable tie of steering gatter.
8. Do both sides.
Original ball joints had split pins - new ones have nylock nuts.
Might only be 60 quid for MOT garage to fit including parts so cheaper than a re test if over 24 hrs.
OR See Works Manual at www.triumph-cars.co.uk/ for pictures in section PDF's to download it.Pages 248 for track rod ends
http://www.ebay.co.uk/itm/TRACK-ROD-END ... 3cca711b13
Image[/URL]
Posted: 06 Sep 2012 16:06
Easy really with the proper tool [;)]
Posted: 06 Sep 2012 18:13
Not mentioned but if you're going to relace the tie rod end while replacing the gaiters, count the number of turns it takes to remove, write it down (so you don't forget) and put new one on with same number of turns to get you close to the right spot. I use a pickling fork to remove tie rod but a little hard on rubber if you're going to reuse it.
Posted: 06 Sep 2012 18:21
by prlee
Easy unless the track rod has seized onto th steering arm, would not shift had to get arage to do it, not expensive though
Pete
Image Image Image
Posted: 07 Sep 2012 02:24
by jclay (RIP 2018)
There is an easy way to remove the ball joint stud from the strut. Remove the cotter pin from the castle nut and break the nut loose. Get a socket from your tool box that will slide over the stud and sit on top of the castle nut and will just touch the bottom of the strut housing. Now loosen the nut, which will push the socket up against the strut housing until where is enough pressure on the nut that it then pushes the stud out the bottom of the strut.
Clay
Posted: 07 Sep 2012 19:46
Are we discussing the track rod end or the lower ball joint on the bottom of the strut?
I don't think the track rod end dust cover is available separately but I've never needed to buy one on its own. I've had to replace the lower ball joint dust covers a few times in the last few years. They don't last more than a couple of years before the rubber splits. Prior to that they lasted over 25 years.
