fuel filler seal rubber
Posted: 24 May 2012 18:49
by mpc
hi new to forum rubber seal perished on fuel filler cap
rimmers do not stock or potential supply any help appreciated
Posted: 24 May 2012 19:05
by DNK
Which one
Don
"No More Cars For You"
71 TR6- Perpetual remodel
80 TR7 V8 Kick in the pants
Posted: 24 May 2012 22:04
I used a piece of foam rubber I got from Michael's (a craft store) for the foam rubber that sits below the top cap and the rubber that seals to the gas pipe lip I used red rubber gasket material to cut out as I believe it is gasoline resistant.
Posted: 25 May 2012 07:06
by John Clancy
I get mine from Robsport - 01763 262263. It's vital the rubber on the petrol cap does not perish otherwise water will get into the tank. And we all know the disastrous consequences of that!
Posted: 25 May 2012 08:48
by Odd
And to further avoid water settling/getting trapped in the fuel filler recess:
Put extra washers (plastic or stainless) <u>between</u> the layers where the screws go through the bottom
of the recess! This makes the drain-through area larger and thus less risk of the recess filling up with
trapped water.
<font color="red"><b>My two 1980 Wedges...</b></font id="red">
Posted: 25 May 2012 10:29
And to avoid it even further blow out the recessed area around the filler neck with compressed air from time to time.
(of course stuff a rag or similar in the fuel fuller neck to avoid dirt getting into the tank)
<center>
Posted: 26 May 2012 02:45
by silverseven
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Odd</i>
trapped water.
I like this idea!!!
Posted: 26 May 2012 07:24
by John Clancy
It is a very good idea! Well done Odd. Even more useful on the large petrol cap cars which have less of a water well and therefore more prone to the water ingress problem.
I have a leather flap mounted over mine to minimize any water getting into the petrol filler neck area.
Posted: 26 May 2012 21:46
by emdee
I made one out of a mouse mat - plastic top, dense foam base
