Interesting front end mods
Posted: 27 Oct 2011 15:02
by Vegas_M
Came across this last night.
More at:
http://www.facebook.com/media/set/?set=a.235582833160759.71453.233236956728680&type=1&l=3da21d6d0a
Martin
[url="https://docs.google.com/leaf?id=0BxOL0HRH5pDeNWRlOTVhZjgtMWE1Mi00ZWNiLWE3ZGYtOWNiODU1Y2JjOGQ0&hl=en_GB"]My TR7v8 Document Repository[/url]
Posted: 27 Oct 2011 16:37
by john 215
Hi Martin
Well spotted [8D]
Intresting mod, allowing for caster adjustment and converting to 'A' frame wishbone suspension.
That is a serious brace the gent has made,
nice bit off engineering, do you know the gent concerned, i hope dont me posting the 2 pictures [8)]
1976 Speke FHC Beauty
Posted: 27 Oct 2011 16:55
I hope he got his welding right [B)]
There are other options though ...
<center>
Posted: 27 Oct 2011 18:20
by mb4tim
Posted: 27 Oct 2011 18:41
by Vegas_M
Beans,
I thought you just mocked that up. Did you actually implement it?
M.
Martin
Posted: 27 Oct 2011 20:24
I am going to implement it when time allows ...
(fixing damage to the DHC at the moment, which probably will take till the end of this year)
<center>
Posted: 01 Nov 2011 15:07
by dursleyman
Do you have a problem with fore and aft movement of the strut as the suspension goes up and down, because there looks to be a difference in length with the two parts of the new arms?
It might cause you some bump-steer problems unless the geometry is spot on. I speak from personal experience on a couple of cars, one was mine many years ago and the other someones else's rally car more recently. It caused spooky handling on both until we realised what was going on.
1980 TR7 DHC
Posted: 01 Nov 2011 16:48
There will always be for/aft movement of the strut under bump/rebound.
But that will be less than with the original set-up.
Most important to avoid bump steer is that the pivot points from the TCA and Tie Rod are in a line (so TCA has same length as Tie Rod) and the TCA and Tie Rod run parallel.
<center>
Posted: 01 Nov 2011 17:38
by Wayne S
Grinnall did something very simialar to all this on his later cars. It was called the "wishbone" upgrade and is found on the round style cars especially.
Posted: 02 Nov 2011 19:35
by frankman
Hello Martin
It looks very stiff - think it brings a little stability - how it looks with the water-cooler?
The engine is a bit down to the left is this normal ? if so how much are the degree in about..
I always thought the engine is taken horizontally (oil pan) [8)]
Hello from Switzerland
Frank
Posted: 02 Nov 2011 22:56
by Vegas_M
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by frankman</i>
Hello Martin
Frank
Frank,
It isn't my car, so I can't comment on the engine. Sorry.
M.
Martin
Posted: 03 Nov 2011 12:04
The only problem with most similar front end modifications is fitting a new anti roll bar in there, with similar or greater roll stiffness. With an uprated suspension such as these it will probably require a stiffer roll bar, & really needs to be adjustable to get best value from the modifications.
Triumph Rover Spares, in Adelaide South Oz had a similar highly developed suspension, developed on their very successful Targa Tasmania car. This was depicted on their web site, & available on a made to order basis.
I noticed this had a nice drop link roll bar incorporated, although I can't remember if it was adjustable.
I'm sure the set up offered would have been developed using roll bars of a number of thicknesses, to get something to suit Ian, the owner. However he is a very exuberant driver, & I expect something a little softer would suit me, & many other drivers better.
The site is well worth a look.
