Posted: 19 Oct 2011 15:04
by Odd
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> ... and know it needs a stronger box. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Then get yourself a R380 'box!
Posted: 19 Oct 2011 15:35
If you are really serious, get a bell housing from Triumph Rover Spares in Adelaide, to fit a Toyota Supra box, & know it will be strong enough.
Posted: 19 Oct 2011 19:42
Typical TR7 5-speed 'box has a number starting with CL-
Posted: 19 Oct 2011 22:48
by Chunk
For any motorsport you wil need a fully reconditioned gearbox including new bearings. Anything secondhand, or worn will let you down. The box from the SD1 with the larger drain plug has slightly bigger bearings, but T5 and Toyota boxes are very popular these days.
1979 TR7V8 FHC.
DJE 4.6 Block and Heads.
22 years of tinkering and tuning......So far!
Now available in red.
Posted: 20 Oct 2011 06:12
by john 215
Hi Kork,
[8D] WELCOME TO THE BEST TR7 / 8 FORUM IN THE WORLD EVER [:)]
Gear box identification,
The identification marks can be found on an oval lug near the base of the box
G16A SD1 2000 (Could be 4 speed)
G17A SD1 2300/2600 5 speed
G19A SD1 3500 SE/VP 5 speed
G22A SD1 3500 Police spec 5 speed
G23A SD1 2600 Police spec 5 speed
G26A SD1 2400 Diesel 5 speed
G27A SD1 2000 Later model 5 speed
G28A SD1 Vitesse 5 speed
G30A Sherpa Range
For hard use my learned friends Odd and Chunk have the correct idea, but running a late LT77 behind my 4.6
1976 Speke FHC Beauty
Posted: 20 Oct 2011 19:56
According to Jon Wolfe the original TR7 5 speed 'box is up to the job if you are developing around 300 BHP from your engine.
Posted: 21 Oct 2011 05:52
Both John Buffum and Bob Tullius used the LT77 gear box with the road racer developing 360 hp I believe and for longer endurance events it was detuned to 300 to 330 hp range. They didn't use the 5th gear (overdrive) considering it the weak point of the transmission. Mind you the Toyota transmission might be better shifting and last longer, don't know.
Posted: 21 Oct 2011 13:18
by frankman
aaaaah we see a number of gearbox .... sniiff[:(]
Hello from Switzerland
Frank
