Engine testing
tipo158
Engine testing
Postby tipo158 » 19 Sep 2011 16:20
I got the engine from my TR7 mostly reassembled now. However, the car is no longer mine, so I don't have it to use as an engine test stand.
The engine is on a normal stand now. There is not quite enough room on the back to fit the flywheel.
Any ideas for how I can test the engine given the situation?
alan
Marko
Postby Marko » 19 Sep 2011 17:55
I don't understand you, what do you want to test?
If you can turn the engine over with a big enough socket wrench on the front pulley bolt , and the engine can turn without anything blocking it it is probably assembled correctly and nothing will hit each other(valves-pistons).
Without a flywheel you cant turn the engine over with the starter to do a compression test.
Leakdown test can be performed.
But it wont show you anything right since the engine is freshly assebled, ppiston ring have not bedded in themselves.
tipo158
Postby tipo158 » 19 Sep 2011 19:38
I am trying to figure out what I can test. I want to test as much as I can to confirm that it is correctly assembled.
I can get bolts onto the crank and turn the engine by leveraging a breaker bar between the bolts. If I could get another 1/4 inch between the back of the stand and the engine, I could get the flywheel on. But the stand is using two of the three starter bolt holes in the adapter plate, so ...
alan
Marko
Postby Marko » 19 Sep 2011 20:55
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tipo158</i>
you'll just ruin the thread on the bolts that way.
There's a big socket on the front engine pulley that you can turn the engine easily with , especialy without the sparkplugs.
Other than checking if the engine is turning you cant do anything else.
With the camshaft cover off you can check if it is phased right, adjust valve lash. and that's it.
tipo158
Postby tipo158 » 19 Sep 2011 21:09
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Marko</i>
They were already ruined. I have another set for the flywheel that I will use.
Uh, there isn't a crank pulley bolt yet. But there will be soon though.
How about oil pressure and flow? Or does the engine need to be turning at engine speed for the oil pump to work?
Another question - can the block-to-gearbox adapter plate hold the whole engine weight (without the front supported like it would be if the engine was in the car) for an extended period of time?
alan
Marko
Postby Marko » 20 Sep 2011 08:08
Nope , engine has to turn much faster than you cant turn it by hand [:D]
Unles youre Chuck Norris. [:D][:D][:D][:D]
That plate is 5mm(-ish) thick and it isnt designed to be stressed in bending , it designed to hold the engine torque.
Depending on what bolts on the plate you secure it, the whole engine could wobble on it like a weigh on a spring, bare engine is realy heavy.
There is enough mounting points on the side of the engine, why dont you mount it there? Engine mounts to those holes anyway when in the engine bay.
Postby FI Spyder » 20 Sep 2011 15:55
The engine is supported by the bottom mount with side mount to take up torque. Never thought of mounting from side. That would allow you easy access front and rear. Would it work? Any one mounted it from there? I always thought you mounted from flywheel side after bellhousing and flywheel is removed.
Postby Beans » 20 Sep 2011 16:30
... Any one mounted it from there? ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Dolomite 1850 used engine mounts fitted to both sides of the engine.
tipo158
Postby tipo158 » 20 Sep 2011 17:06
I think that I should probably get the engine off of the stand. Got some wheel dollies that I can attach some framing to for the engine to sit on.
Then again, I am getting the sense that I am building the engine only to have to throw it out after I get done (as there hasn't even been a nibble). But I am learning stuff, so I am getting what I wanted out of it.
alan
Postby FI Spyder » 20 Sep 2011 18:17
The problem is getting a good rebuilt engine from a reputable machine shop leave alone someone doing it to learn stuff, that's why you want to do it yourself. Club member has a professionally rebuilt engine that still burns a quart/litre of oil per one thousand miles after 4,000 miles driven (smokes). Shop says he has to drive it 6,000 miles to break it in. (might be Km). What do you bet the warrany expires at 6,000?[:p]
tipo158
Postby tipo158 » 20 Sep 2011 20:26
Yeah, but a) this isn't my first engine (it is my fourth) and b) the asking price is what one would pay for a used motor (and the "will take" price is much less.
In the local places where it is listed, it just says "rebuilt but not run" with no reference to who did the rebuild and no one has even called to ask. Seems like the other local people selling TR7 bits on craigslist aren't getting much action either because their ads keep getting renewed, but the items that they are selling remain.
Are these engines prone to leak even when built correctly?
The Lotus 907 engine that I did for my Esprit was supposedly a leaker, but mine didn't leak after I did a top end rebuild/water pump/timing belt (25k mile timing belt - yuk!) on it. Seemed like the stuff around the engine was dependent on the leaks for corrosion protection because rust start popping up down there afterward.
alan
Users browsing this forum: No registered users and 167 guests
