TR7 headlights
jcorcoran118
TR7 headlights
Postby jcorcoran118 » 31 Aug 2011 13:21
I have a 1979 TR7 coupe. The headlights both go up BUT the pasenger side headlight does not go down. Any suggerstions?? Thanks.
pupinabox
Postby pupinabox » 31 Aug 2011 13:41
I would start by checking the relays. Also take a look at the headlight switch. Remove it and give the connections a good cleaning, keeping in mind the switch is old brittle plastic and to use care.
[IMG=left]http://i160.photobucket.com/albums/t194/pupinabox/tr7005.jpg?t=1271517043[/IMG=left]
trekcarbonboy
Postby trekcarbonboy » 31 Aug 2011 15:24
I had the same problem and was lucky that I only had to clean the connections down at the motor. Didn't really make sense that the lights would go up but not down with bad connection.
Craig '75 2.0 FHC
tr7sprint1
Postby tr7sprint1 » 31 Aug 2011 16:38
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pupinabox</i>
I would start by checking the relays. Also take a look at the headlight switch. Remove it and give the connections a good cleaning, keeping in mind the switch is old brittle plastic and to use care.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
if that doesn't work you may have to lube the pivot(hinge bolt)point. the bolt may have some crud/rust build up.
Users browsing this forum: No registered users and 278 guests
