Screw Type Oil Filter
Posted: 17 Aug 2011 19:59
by dursleyman
I just acquired a screw type oil filter adapter but it came without a filter. Does anyone know what type they usually use or are there any ones to avoid?
1980 TR7 DHC
[http://www.flickr.com/photos/16162151@N05/5921648270/in/photostream]
Posted: 17 Aug 2011 20:22
by prlee
Hi Russ mines a Fram PH2964
Pete
Image Image Image
Posted: 18 Aug 2011 00:49
Stay away from Fram, they make the worst ones. Purolator or WIX is the best. (last test I read, a few years ago). Google oil filter tests, there are lots of independent tests out there.
Posted: 18 Aug 2011 16:20
I use Bosch P2056
Posted: 18 Aug 2011 20:50
by prlee
My filter came with the kit, I fitted it before I heard it had a reputation, at least with the Fram code you can get another make from the local motor factors.
Pete
Image Image Image
