front susp. poly bushes
Posted: 18 Jun 2011 11:24
by Jez
I have some super pro poly bushes that just don't seem to fit quite correctly, they seem a bit too tight. They are the upper bushes for the front suspension. when I have released the spring onto them it just doesn't seem quite right. Has anyone else had this experience? Or know what to do? They are the right part number.
Jez
11/80 Inca Yellow TR7
Posted: 18 Jun 2011 11:39
by bmcecosse
" Upper bushes for the front suspension" - I'm not getting you - where are these bushes fitted??
Image Image ImageImage
Posted: 19 Jun 2011 03:04
by Jez
Top of the spring.
Posted: 19 Jun 2011 03:32
by V8Wedgehead
Are you sure they are not the tops for the rear? The front and rear springs have the same diameter but the fronts are longer than the rears and you could swap the upper spring seat bushings? I had seen the two can easily be confused and they are different.
Michael
1980 TR8 FHC #0020 Rally Conversion
Posted: 19 Jun 2011 07:14
by Jez
Thanks, I had better check that out. Wont be until next weekend now, too cold of an arvo.
