I need to change the soft gearbox rubber mount on my V8 Grinnall. Is it just a case of undoing the four cross member nuts - are they fixed studs on through the floor or are they bolts that I will have to hold inside? - plus the big centre bolt and jiggling the assembly around the exhausts to replave the rubber then reverse. Do I have to take the crossmember off at all ?
Any advice much appreciated
David
