spotlights
rocky_679
spotlights
Postby rocky_679 » 22 Mar 2011 07:41
heres goes ive put som 6 inch spotlights on the front bumper just wondered what is the correct way to wire them up so they are legal...[:D]
stephen j dark
willywonka
Postby willywonka » 22 Mar 2011 07:52
I believe you have to take a feed from the main beam via a switch, then to the switching side of the relay. That way you can knock the spots off when not required and just run the main beam.
All the Gear, no idea
Postby andyf » 22 Mar 2011 07:53
If it is spotlights, then through a separate switch and to the high beam circuit so they only come on with high beams.
If they are fig lights, there should be wiring in place behind the bumper so that you can use the first position on the fog lamp switch. Although bizarrely with mine (I assume all are the same) they do not run through the headlamp circuit, meaning they are on all the time and you have to remember to switch them off with the fog lamp switch.
edit - should point out as ww has said - through a relay.
1980 Persian Aqua DHC
rocky_679
Postby rocky_679 » 22 Mar 2011 08:05
thanks guys just needed to make sure have the relay n wiring kit i was thinking of wiring them up to a completely seperate switch on the dash so they wouldnt interfere with wiring loom lighting
stephen j dark
Postby stevie_a » 22 Mar 2011 18:06
Postby nervousnewowner » 22 Mar 2011 18:30
always wired my spots to main beam whatever the car, kelvin nice to see your still around and andy hows the engine work going?
prlee
Postby prlee » 22 Mar 2011 19:15
For the MOT you must have a warning lamp to show when the spotlamps are on. They should be connected via the normal hi beam switch but can have a switch in the circuit so you can disable the extra spots and just have standard hi beam only, but this is not compulsory. You need warning lamps for additional lighting, including rear fog lamps but not front.
On my Spitfire I have separate fused wiring to the spots, these are switched via a relay form the normal hi beam wiring. The warning lamp is the normal hi beam lamp. So the lamps come on with the standard hi beam.
Many years ago a MOT tester told me that if I had spots the normal headlamps had to stay on dipped, but he was wrong.
Pete
81 Red DHC
79 Blue Spitfire
Image Image Image
Postby REPLIC8 » 23 Mar 2011 06:38
My front spotlights work independantly from the headlights. If the lights fail to pop up at least I've got a back up to get home at night. [:)]
[img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/small_175-2.jpg[/img][/img] [img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/pics005.jpg[/img][/img]
rocky_679
Postby rocky_679 » 23 Mar 2011 08:23
thanks guys[:D]
stephen j dark
willywonka
Postby willywonka » 23 Mar 2011 12:09
Your warning lamp can be in the form of an illuminated switch.
I also fit a spare relay next to the operational one in case of failure on my rally cars.
Postby andyf » 24 Mar 2011 07:56
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nervousnewowner</i>
Hello Dave, the engine work isn`t going at the moment, but within the next two weeks I intend to have that head off. Famous last words and all that
Users browsing this forum: No registered users and 299 guests
