Gearbox torque
Gearbox torque
Postby nick » 21 Mar 2011 17:51
The Leyland Manual has a list of torques for nearly everything. So I looked up the gear box ones since I'm putting the front and rear covers on my 5 speed. The torques called out for the gearbox to cover are 10 foot pounds or 13nm. That's hardly more than hand tight. I went to 20 lb/ft and it still seems like not enough. Is spec that low in order that the gasket not get compressed too much?
'79 TR7
Postby DNK » 21 Mar 2011 17:57
Torque usually has to do with the bolt size and what it is going into.
"No More Cars For You"
71 TR6- Perpetual remodel
Marko
Postby Marko » 21 Mar 2011 20:02
dont forget to clean the threads with a tap, and lube the thread before torquing down, that way, small torque makes good enough tension on the bolt.
And flanges are torqued down in sequence , so after couple of passes across all bolts , the stuff is rigidly clamped.
