steering column shroud !
slider
Postby slider » 10 Mar 2011 20:49
hi folks, does any body have a steering column shroud unit(the plastic two part pieces that go between the boss and dash) they could sell me as my 2 screws would not unscrew and broke inside. It looks untidy(and like i hotwired it) many thanks i will keep looking............[:(]
Postby nick » 10 Mar 2011 23:04
I see them all the time on ebay.
'79 TR7
Postby PeterTR7V8 » 10 Mar 2011 23:27
When part that holds the brass threaded bush sits inside the top shroud broke I repaired mine with glue & a small hose clamp. This repair seems to be going the distance.
There are 2 types of shroud designs I think for when the key was moved to the other side of the column. Not to mention RHD/LHD.
Postby FI Spyder » 11 Mar 2011 01:10
Try Robsport or S&S Prep. to see if they have a used part/s.
slider
Postby slider » 11 Mar 2011 15:02
will have to try your suggestion's as it looks awful without it[:I]i did try repairing mine but to no avail[:(]
rosey
Postby rosey » 11 Mar 2011 18:37
is it black or grey?
I probably have one spare that you can have.
Dave
1981 Purple Grinnal 2.0L
Honda Civic Type R GT in red!
moestr7v8
Postby moestr7v8 » 11 Mar 2011 22:53
Hi Andy I think I might have a set in the garage somewhere,might take a couple of days to find [;)], I will let you know but I am pretty certain that i don't have any screws though.
Moe
slider
Postby slider » 15 Mar 2011 21:00
hi and thanks(both of you), its black in colour. where the brass nut(screw thing is)just dissintergrated as i tried to unscrew it[:(!]but hay ho! shit happens[:D]
slider
Postby slider » 15 Mar 2011 21:04
SORRY! grey in colour[:o)][:D]the carpets are black(untill the grey set goes in)
rosey
Postby rosey » 16 Mar 2011 17:55
I only have a black one but the Grey ones were sprayed over black anyway, if you want it then send me a PM with your address and you can have it for the postage cost.
Dave
moestr7v8
Postby moestr7v8 » 17 Mar 2011 22:24
Hi Andy after much searching I can only find the half with the threads in,upper half,a repair was done to it on one of the thread inserts but it looks permanant even if it does look rough[;)].
Problem is it is black but you are welcome to it if it is any use.
Moe
Users browsing this forum: No registered users and 224 guests
