Fuel Tank/Sender Unit
cozyheatdave
Postby cozyheatdave » 05 Mar 2011 20:08
I'm installing a new tank in my TR7. I will be using a V6 engine, so it isn't standard TR7.
I bought from Rimmers Part #TKC3415 which is the Sender Unit for the TR8.
Now I don't see where the fuel line to the engine connects.
I'm assuming I have the wrong sender unit.
How does the TR8 get it's fuel?
If I order the Part #TKC3408 will it have a pick-up tube?
Second, can I install the sender unit after the axle is installed?
I couldn't repair my brakes, so I made my horn louder.
[img=left] http://i887.photobucket.com/albums/ac78 ... 1296600038 [/img=left]
Postby REPLIC8 » 05 Mar 2011 21:10
If you have a standard TR7 tank then you need part TKC3408. This incorperates the fuel sender and the fuel pipe in one unit. The TR8 has a twin hole tank which uses part TKC3415 in one hole and a seperate electric fuel pump ( no longer available) in the other.
jrich4411
Postby jrich4411 » 05 Mar 2011 22:14
Dave, I'm pretty sure that to install & remove the tank you need to drop at least one side of the rear axle to make enough room for the tank to come in & out. I don't think you can get to the sending unit without dropping the tank.
'80 DHC
Chevy V8 up front
Ford rear end down back
Lucas wiring all over
Postby Hasbeen » 05 Mar 2011 23:22
Dave, fortunately for you & all of us Andy has that wrong. Although Craig in the other thread is having trouble with removing a fuel sender, I have not had a problem.
It should only take a few minutes, [say 20] to do the remove & refit, unless everything is very rusty.
You should replace the gasket, & perhaps a new lock ring would be a good idea, if you have much rust elsewhere in the car.
Just slide underneath, & you'll find it in the front of the tank, with plenty of access.
Postby jclay (RIP 2018) » 06 Mar 2011 00:52
Never say never!
TR8 Fuel Pump carbed fuel pump: AIRTEX Part # E3027, $33.99, rockauto.com. {In Tank Electric Fuel Pump}: 1975 CHEVROLET VEGA 2.0L 122cid L4 FI (O) : Fuel/Air : Fuel Pump. The strainer is FS100.
http://web.me.com/jclaythompson/Technical/Parts_List.html
[url="http://web.mac.com/jclaythompson/Site/Welcome.html"]My Triumph Site[/url], [url="http://web.me.com/jclaythompson/Technical"]Technical Stuff[/url], [url="https://docs.google.com/?hl=en&tab=wo&authuser=0&pli=1#all"]Download Page[/url], [url="https://public.me.com/jclaythompson"]My Public Folder[/url], [url="http://web.me.com/jclaythompson/tr8/Welcome.html"]My TR8 Site[/url]
cozyheatdave
Postby cozyheatdave » 06 Mar 2011 00:56
Thanks guys. I will find the right sender unit and Apparently have a brand new TR8 sender unit available.
Postby FI Spyder » 06 Mar 2011 01:53
That would be the same part used in the TR7 FI which also uses a twin hole tank with no hose in sender unit and an in/out set of hoses in second hole for fuel circulation through the pump to cool it.
Postby REPLIC8 » 06 Mar 2011 12:45
Hasbeen,
I think what I said about the sender/pump was correct. I never mentioned anything about removing the sender because I've only done it with the tank out. [:)]
Postby Hasbeen » 06 Mar 2011 13:24
Yes Andy, I think I miss read your post.
Users browsing this forum: No registered users and 252 guests
